Hello ,
I have had dopus for a few version now. Just recently decided to get this to start working for me.
I do animations and as such i have a large number of frames in a dir and want to copy them to my SSD drive to be complied into a video. I have tried the "Copy To" and it works great so of course I started to perfect it. I add a advance line arguments, Select all, which worked swell. the copy to function i hard coded the destination dir, work great, but i cant get the @filesonly modifier to work.
I have tried it in different line and none work, it always copies any dir in the source folder. If i am reading this correctly, the modifier should tell only copy files not folders correct. I tried these different combination, as i couldnt find a syntax to show how these scripts are laid out.
select all
@filesonly
Copy to =l:
@filesonly
select all
copy to =l:
select all
copy to =l:
@filesonly
select all
@filesonly copy to=l:
