Filter Bar: Escaping plus and minus with plus?
The dropdown doesn't offer anything for literal + and -.
A single quote doesn't work as an escape sign, but a + does.
Is this the intended way to do it?
In "Match Any Word" mode, anything starting with + - or . will be treated specially.
There isn't currently a way to escape that (something we need to think about/discuss), but you can use *+* *-* and *.* to avoid that and search for those characters anywhere in the string.
++ +- and +. are also fine, but would mean that character must appear, which is slightly different (but usually what you want anyway).
