I am trying to define a file filter subclause that selects only lossless WebP images, but I can't figure out which attribute to use to make the filter work. The Description column shows the information I am looking for in the file viewer, but the Description attribute available for filters does not contain that same information.
I think Description in filters may only search explicitly set description (sometimes called "User Comment"), not automatically generated ones. "Description" is an overloaded term here, unfortunately.
But if you drop this small script on to Preferences / Toolbars / Scripts or into the /scripts folder alias (type it into the path field and push return), it will add a new column available for searching which contains the same string as the automatic description column:
