Filter help
I need help to create filter to select files.
I use dupe utility to find duplicate files and I need to select all files with "TW03" in path.
Is it possible ?
I try with the matching command "location" but don't work :cry:
Checked Used wildecards and use TW03 as name. That worked for me.
:cry:
Don't work for me...
My Collection...
I want to select all files with MARS somewhere in path...
The problem is because your real path is col://Doublons not your file locations and DOPus look at real path when you choice Location. I didn't have any solution idea for the problem at yet, I will think more and if I find any one, I will let you know certainly.
Best Regards
