Find within a script column wiith wildcards
With the find panel that comes up with Control-F it's possible to search within a script column. Is it possible to get the additional options like 'Use wildcards', 'Case sensitive', 'Use regular expression' etc on a script column find? I mean the same options that I see when searching for a filename, say.
Thanks.
Yes, with the Evaluator, e.g.
=Match(Val("scp:ASIN/ASIN"), "^b\d\d.*", "r")
Match
Looks very promising, but I can't get the search right, Alexander. What do I choose here?
Can you be more specific?
Clauses like this work:
=modified>"2024-06-20"
Control-F to bring up the advanced find panel. I can use an evaulator expression to search a script column, but I cannot find what to choose from the list I screenshotted above.
Where exactly are you entering your evaluator expression?
You need to check Edit as text.
(You can't uncheck this after entering an textual filter evaluator clause)
Works perfectly. Thank you, Alexander.
Incidentally script column searching uses regular wildcards by default.
Thank you. It was actually a regular expression I was after.
