Fix Filename Column
Hello
the following idea came me evenly, when I paged through files with many additional columns: Like waer's, if one had the possibility, the 1. Split (usually file name) as into Excel to fix, while one scrollt by the columns?
Thanks
Stefan
You mean so that the first column is fixed and doesn't scroll when the others do? Maybe right-clicking a column heading and selecting "Lock" to specify that it and any columns to the left of it won't be scrolled.
That could indeed be useful, although I don't know how easy it would be to make it possible.
Hello, just(exactly), so the function was meant.
Stefan
