Flat View & Libraries
Is it possible to set a library to flat view by default?
I have got my libary set and am currently manually making them go to flat view when veiwing them, is there a way in which i an make flat view as soon as i access the library?
Thanks
mark
NZ
Following seems to work. You may modify it to your purpose:
Go /libraries\documents Set Flatview=Grouped
This applies to a hotkey or button, to use this code with, but if you want to access your libraries by the tree, i think
there's no direct way to do that at the moment.
Creating a Style which goes to the folder and turns on Flat View is another option.
(The style will have the same result as Abr's button suggestion, but might be nicer if you already use styles for other things or if you find it easier to create a new style using the GUI rather than add a custom button. Equally, Abr's button may be better for you, depending on what you want.)
