Hi,
We are having issues when we load a CD/DVD with images we cannot use the the flat view its grey out.
Loaded other mixed data no images with folders and the content seems to be ok.
Running 64Bit OS Vista
Cheers,
Hi,
Cheers,
It's because the CD is writable, and Opus is displaying the Explorer interface. You can disable this by turning off the "Use system display for writeable CDs" option in Preferences / Miscellaneous / Windows Integration.
Hi Jon
Thnx that was a quick fix man o man should look harder next time.
Cheers,
