Name Size Format Modified Property
The widths of the above items are not retained the next time you open them.
The next time you open the same tab, you have no choice but to adjust it again?
You can set and save the widths to anything you want, as well as various auto-size/fill/collapse modes.
This covers everything in great detail:
You may also find this useful:
It looks a bit complicated, but let's try
Thank you ~
