I switched from dual view to single and back to dual again. Both listers are same location, but the folder format for the left lister is wrong.
Presumably your "Single" style overrides the folder format but your "Dual" style does not. That isn't a bug, it's just how you have things configured.
It could also be that both styles are set to View Mode: Auto (which is the default) and the view mode only needed to be changed when the first style was selected. But that would not be a bug either.
(I've removed the bug tag.)
Thanks for help. Thought i'd unchecked the lower boxes ages ago. Do these styles auto-update ? (like when closing dopus ?)
No, they only update when you explicitly update them.
