I set a Folder Format in include Name, Size (bytes), Date and Time (modified) and Attributes. But if the folder contains images, Dopus adds Size (auto), Type, Dimensions, and Date Taken. How do I stop Dopus from adding the those columns? I know I can turn off "Enable Folder Content Type detection" in settings and Dopus will not add the image columns, but I don't want to do that either. I want Folder Content Type detection for other folders. Am I missing something in the Folder Format settings?
Check that Include columns from other matching formats is off for the saved format.
Please link your account if you need more detailed help.
OK, I got it to work. However, when I right-click on the column headings to set the folder format, the option "Include columns from other matching formats" is not there, but it is there when selecting Preferences/Folder Formats. Is that by design or is it a bug?
Account is now linked.
That's by design. It's convoluted to explain but works as intended.
