Folder format for CD and DVD drives
From the manual:
Default Formats: ... Removable Drives: The default format for removable drives like CD-ROMs ...
After some tests:
CD and DVD drives, for me, use the Custom Default Format. Probably as Removable Drives, are considered the usb drives and nothing else.
I have not found evidence in the manual
some clarification?
Yes you're correct, it's an error in the documentation.
Ok, thanks
