Hi,
I cannot get the folder formats working (in the way I think they ought to) Its only affecting the Downloads folder right now. Well it may be the same for others, but its the downloads folder that is niggling me!
Whenever I open a new lister and go to downlloads folder its always expanded to the max size (auto sized). I prefer a dual pane so it means that I can't see the other field titles, to be able to sort by date time etc.
I have explored the folder formats and can apply a favourite format to the folder which works. I have also unchecked the auto size of folders in list view in folder formats. I had also edited the default folder having set the widths in the lister view. Can't see why this folder does not stick to that, I'm guessing there is another setting somewhere in the myriad of options
Its a small thing I know, but I'm sure I just need to find the right config ticks to set it the way I want.
Can someone point me in the right directionm please?
Ta
