Folder Formats with regular expression
Hi
Can anyone help me with regular expressions?
I have a similar structure
C:\Folder 1 | |-->subfolder 1(first child folder) | | | |->subfolder X(second child folder) | | | |->subfolder Z | | | | |-->folder...(first child folder) | | | |->folder...(second child folder) | | | |->folder... | | | | | |-->folder...(first child folder) | | | |->folder...(second child folder) | | | |->folder...
I wanted to set a "Folder Formats" dedicated to all first and second child folders (but not the third)
I can do it?
Thanks
I created two paths Folder Format
[code]C:\Folder 1+$
C:\Folder 1\[^\]+$[/code]
It seems to work
But I did it right?
The first one allows :
C:\Folder 1
C:\Folder 11
C:\Folder 1111
Is that what you intended?
If you just want level 1 and level 2 folders, generically, you can do:
C:(\[^\]+){1,2}$
Which says 1 or 2 folders from C: and that's all.
Yes, I wanted the 1 and 2 level folders
I tried as you suggested, and it works as intended (then using only one Wildcard Path Format)
Thanks
