Folders in left panel not being saved
I'm using the very latest DOpus on Win10 x64. When I close DO, be it momentarily or before a reboot, and then open it again, the tabs in the right panel are saved, which is good.
However, the tabs in the left panel are not saved, which is bad.
How do I get the tabs in the left panel to be saved?
Thanks in advance!
How are you opening the new window afterwards? Are you double-clicking a folder?
If it is via double-clicking a folder, turn on Preferences / Launching Opus / Explorer Replacement / Open all Default Lister tabs when opening a new window.
I always open DO with the WIN+E shortcut.
Excellent! That did the trick! Thanks very much.
One other question while you're here: is there any way to prevent DO from closing an entire panel when you close the last tab it contains?
Win+E is a Windows hotkey to open the My Computer (aka This PC) folder. If you want it to open the default lister instead, you can get that by overriding the hotkey so it runs "go new".
Although there are sometimes problems replacing Windows hotkeys so you might want to use another instead. By default, Opus has Win+Shift+E set to open a new lister. (Win+O in older versions, if your config dates back to a much older version of Opus.)
Win+E was already assigned "go new" when I checked it just now. I didn't know about the "go new" command, so if I changed it myself, I must have assigned Win+E to something that already had "go new" assigned to it. In any case, things are working fine and dandy now! Thanks again.
