For programs, an x32 / x64 column would be helpful
for programs, an x32 / x64 column would be helpful
Is that so?
You are able to make a custom column that would do this.
I found this stackoverflow answer, that indicates a method by checking the exe file how-to-check-if-a-binary-is-32-or-64-bit-on-windows.
For how to do that as a dopus custom column you can check this script that does something similar. real-header-file-type-extension
If you link your account someone might do it for you.
@qiuqiu nice, what column is that?
is this
option explicit
'const SecsPerDay = 86400
' Column Collection
' (c) 2017 qiuqiu
' This is a script for Directory Opus.
' See http://www.gpsoft.com.au/DScripts/redirect.asp?page=scripts for development information.
' Called by Directory Opus to initialize the script
Function OnInit(initData)
	initData.name           = "Column Collection"
	initData.desc           = GetResString("ScriptDesc")
	initData.copyright      = "qiuqiu"
	initData.version        = "1.1.6"
	initData.min_version    = "12.0"
	initData.default_enable = True
    initData.config.Debug = True
    initData.config.TextFiles = ".asp.aspx.asax.ascx.ashx.bat.cmd.c.h.cs.cpp.hpp.cc" & vbCRLF & _
                                ".c++.css.csv.ini.inf.pas.dproj.bdsproj.dpr.dpk.dfm" & vbCRLF & _
                                ".fmx.nfm.xfm.lfm.e.groovy.html.htm.shtml.hta.inc"   & vbCRLF & _
                                ".jsl.java.jav.jsp.js.jse.json.log.pl.pm.plex.php"   & vbCRLF & _
                                ".php4.phtml.ps1.py.pyw.rb.rbx.erb.resx.sql.tcl.txt" & vbCRLF & _
                                ".vbs.cls.vb.bas.xml.dtd.xhtml.xsl.xslt.wpl.xsd.xs"
    initData.config.ExeFiles =  ".exe.dll.ocx.cpl.8be.8bi.apl.8bf.8li.8bx.8ba.8me.bpl.lld"
    initData.config.SiLength = 5
    initData.config.AgeUnit  = DOpus.Create.Vector(0,GetResString("UnitAuto"), GetResString("UnitMinutes"), GetResString("UnitHours"), GetResString("UnitDays"), GetResString("UnitWeeks"), GetResString("UnitMonths"), GetResString("UnitYear"))
    initData.config_groups   = DOpus.Create.Map("TextFiles", GetResString("TextFilesDesc"), "ExeFiles", GetResString("PEFilesDesc"), "Ageunit", GetResString("AgeUnitDesc"), _
                                                "Debug", GetResString("DebugDesc"), "SiLength", GetResString("Other"))
    initData.config_desc     = DOpus.Create.Map("SiLength", GetResString("SiLength"))
    Dim col
	Set col       = initData.AddColumn
	col.name      = "IsEmptyFile"
	col.method    = "OnGetCol"
	col.label     = GetResString("IsEmptyFile")
	col.justify   = "center"
	col.autogroup = True
    col.match.push_back(CStr(True))
    col.match.push_back("")
	col.name       = "IsModified"
	col.label      = GetResString("IsModified")
    col.grouporder = "Never Modified;Modified"
    'col.autogroup   = False
    col.name      = "Platform"
    col.label     = GetResString("Platform")
    col.match.push_back("32-bit")
    col.match.push_back("64-bit")
    col.name        = "TextEncode"
    col.label       = GetResString("TextEncode")
    col.justify     = "left"
    Col.defwidth    = 70
    ' Set col         = initData.AddColumn
    ' col.name        = "AccessAge"
    ' col.method      = "OnGetAge"
    ' col.label       = GetResString("AccessAt")
    ' col.justify     = "Right"
    ' Col.defwidth    = 70
    ' col.autorefresh = True
'    col.autogroup   = False
    col.name        = "CreateAge"
    col.label       = GetResString("CreateAt")
    Col.defwidth    = 70
    col.name        = "ModifyAge"
    col.label       = GetResString("ModifyAt")
    Col.defwidth    = 70
    'Signature
    col.name        = "Signature"
    col.label       = GetResString("Signature")
    col.justify     = "Left"
End Function
Sub LogMsg(ByVal Message)
    If Script.Config.Debug Then DOpus.Output(Message)
    'DOpus.Output(Message)
End Sub
Function GetResString(ByVal ResName)
    GetResString = DOpus.Strings.Get(ResName)
End Function
' Function:    FormatMessage
' Purpose:     Slot-based string formatting function.
' Example:
'   Dim str
'   str = FormatMessage ("Hello, Mr. %1%, today is %2%.", Array("McNeel", Date))
Function FormatMessage(strMessage, arrArguments)
  Dim strResult, i
  strResult = strMessage
  For i = 0 To UBound(arrArguments)
    strResult = Replace(strResult, "%" & CStr(i+1) & "%", CStr(arrArguments(i)))
  Next
  strResult = Replace(strResult, "\n", VbCrLf)
  strResult = Replace(strResult, "\t", vbTab)
  FormatMessage = strResult
End Function
' Function:    Printf
' Purpose:     Works like the printf-function in C/C++.
' Arguments:   A string with format characters, and an array to expand.
'              The format characters are always "%x", independent of the type.
' Example:
'   Dim str
'   str = Printf("Hello, Mr. %x, today is %x.", Array("McNeel", Date))
Function Printf(strMessage, arrArguments)
  Dim strResult, intPosition, i
  strResult = ""
  intPosition = 0
  For i = 1 To Len(strMessage)
    If Mid(strMessage, i, 1) = "%" Then
      If i < Len(strMessage) Then
        If Mid(strMessage, i + 1, 1) = "%" Then
          strResult = strResult & "%"
          i = i + 1
        ElseIf Mid(strMessage, i + 1, 1) = "x" Then
          strResult = strResult & CStr(arrArguments(intPosition))
          intPosition = intPosition + 1
          i = i + 1
        End If
      End If
    Else
      strResult = strResult & Mid(strMessage, i, 1)
    End If
  Next
  Printf = strResult
End Function
'*     Shl(AnyNumber, BitsToShiftBy)
'*         Returns a new number with bits shifted. 0's are shifted in from the
'*         right, bits will fall off on the left.
Function Shl(Number, Bits)
    Dim Result, tmpValue, i
    tmpValue = Number
    For i = 1 to Bits
        Select Case VarType(Number)
            Case vbLong
                Result = (tmpValue And "&H3FFFFFFF") * 2
                If tmpValue And "&H40000000" Then Result = Result Or "&H80000000"
                Result = CLng(Result)
            Case vbInteger
                Result = (tmpValue And "&H3FFF") * 2
                If tmpValue And "&H4000" Then Result = Result Or "&H8000"
                Result = CInt("&H"+ Hex(Result))
            Case vbByte
                Result = CByte((tmpValue And "&H7F") * 2)
            Case Else: Result = 0 ' Not a supported type
        End Select
        tmpValue = Result
    Next
    Shl = Result
End Function
'*     Shr(AnyNumber, BitsToShiftBy)
'*         0's are shifted in from the left. Bits will fall off on the right.
Function Shr(Number, Bits)
    tmpValue = Number
    For i = 1 to Bits
            Case vbLong
                Result = Int((tmpValue And "&H7FFFFFFF") / 2)
                If tmpValue And "&H80000000" Then Result = Result Or "&H40000000"
            Case vbInteger
                Result = Int((tmpValue And "&H7FFF") / 2)
                If tmpValue And "&H8000" Then Result = Result Or "&H4000"
                Result = CInt(Result)
            Case vbByte
                Result = CByte(tmpValue / 2)
        End Select
        tmpValue = Result
    Next
    Shr = tmpValue
End Function
' Add a function to show file sizes in short string form
Function FormatFileSize(Size)
	Dim Mult, Exp, Denom
	' Windows supports files of up to 16EB.
	Mult = Array("B","KB","MB","GB","TB","PB","EB")
	Exp = 0 :Denom = 1
	While (Size >= Denom * 1024) AND (Exp < UBound(Mult))
		Denom = Denom * 1024
		Exp = Exp + 1
	WEnd
	FormatFileSize = (Size / Denom) & " " & Mult(Exp)
End Function
Function IsBlank(Value)
	'Returns True if Empty or NULL or Zero
	If IsEmpty(Value) or IsNull(Value) Then
		IsBlank = True
	ElseIf IsNumeric(Value) Then
		If Value = 0 Then IsBlank = True  'Special Case Change to suit your needs
	ElseIf IsObject(Value) Then
		If Value Is Nothing Then IsBlank = True
	ElseIf VarType(Value) = vbString Then
		If Value = "" Then IsBlank = True
	Else IsBlank = False
	End If
End Function
Function IIf(ByVal Expression, ByVal TruePart, ByVal FalsePart)
    If Expression Then
		If IsObject(TruePart)  Then Set IIf = TruePart  Else IIf = TruePart
	Else
		If IsObject(FalsePart) Then Set IIf = FalsePart Else IIf = FalsePart
	End If
End Function
Function HHex(ByVal Value)
    If Len(Hex(Value)) Mod 2 Then HHex = "0" & Hex(Value) Else HHex = Hex(Value)
End Function
Function CHex(Number, Bits)
    Dim strChars, intSign
    strChars = "0123456789ABCDEF"
    intSign = Sgn(Number)
    Number = Fix(Abs(CDbl(Number)))
    If (Number = 0) Then
        CHex = Right(String(Bits, "0"), Bits)
        Exit Function
    End If
    While (Number > 0)
        CHex = Mid(strChars, 1 + (Number - 16 * Fix(Number / 16)), 1) & CHex
        Number = Fix(Number / 16)
    Wend
    If Len(CHex) < Bits Then CHex = Right(String(Bits, "0") & CHex, Bits)
    If (intSign = -1) Then CHex = "-" & CHex
End Function
Function CRoman(intNumber)
    Dim v, w, x, y, arrOnes, arrTens, arrHund, arrThou
    arrOnes = Array("","I","II","III","IV","V","VI","VII","VIII","IX")
    arrTens = Array("","X","XX","XXX","XL","L","LX","LXX","LXXX","XC")
    arrHund = Array("","C","CC","CCC","CD","D","DC","DCC","DCCC","CM")
    arrThou = Array("","M","MM","MMM","MMMM","MMMMM")
    v = ((intNumber - (intNumber Mod 1000)) / 1000)
    intNumber = (intNumber Mod 1000)
    w = ((intNumber - (intNumber Mod 100)) / 100)
    intNumber = (intNumber Mod 100)
    x = ((intNumber - (intNumber Mod 10)) / 10)
    y = (intNumber Mod 10)
    CRoman = arrThou(v) & arrHund(w) & arrTens(x) & arrOnes(y)
End Function
Function CUnRoman(strRoman)
    Dim intvalue, strChar, i
    intValue = 0
    If InStr(strRoman, "CM") Then
        intValue = intValue + 900
        strRoman = Replace(strRoman, "CM", vbBinaryCompare)
    End If
    If InStr(strRoman, "CD") Then
        intValue = intValue + 400
        strRoman = Replace(strRoman, "CD", vbBinaryCompare)
    End If
    If InStr(strRoman, "XC") Then
        strRoman = Replace(strRoman, "XC", vbBinaryCompare)
    End If
    If InStr(strRoman, "XL") Then
        strRoman = Replace(strRoman, "XL", vbBinaryCompare)
    End If
    If InStr(strRoman, "IX") Then
        strRoman = Replace(strRoman, "IX", vbBinaryCompare)
    End If
    If InStr(strRoman, "IV") Then
        strRoman = Replace(strRoman, "IV", vbBinaryCompare)
    End If
    For i = 1 To Len(strRoman)
        strChar = Mid(strRoman, i, 1)
        Select Case strChar
            Case "I" intValue = intValue + 1
            Case "V" intValue = intValue + 5
            Case "X" intValue = intValue + 10
            Case "L" intValue = intValue + 50
            Case "C" intValue = intValue + 100
            Case "D" intValue = intValue + 500
            Case "M" intValue = intValue + 1000
        End Select
    Next
    CUnRoman = intValue
End Function
Function IsArrayDimmed(arr)
  IsArrayDimmed = False
  If IsArray(arr) Then
    On Error Resume Next
    Dim ub : ub = UBound(arr)
    If (Err.Number = 0) And (ub >= 0) Then IsArrayDimmed = True
  End If
End Function
Function Min(ByVal a, ByVal b)
    If a < b Then Min = a Else Min = b
End Function
Function Max(ByVal a, ByVal b)
   If a > b Then Max = a Else  Max = b
End Function
Function PadLeft(ByVal PadStr, ByVal PadChar, ByVal PadLen)
	PadLeft = Left(PadStr & String(PadLen, CStr(PadChar)), PadLen)
End Function
Function PadRight(ByVal PadStr, ByVal PadChar, ByVal PadLen)
	PadRight = Right(String(PadLen, CStr(PadChar)) & PadStr, PadLen)
End Function
Function BlobToHex(ByVal BlobValue, ByVal Spaced) 'Spaced = 1, 2, 4, 8, 16
    If DOpus.Typeof(BlobValue) = "object.Blob" Then
        Dim i, Result
	    If Spaced = 1 Or Spaced = 2 Or Spaced = 4 Or Spaced = 8 Or Spaced = 16 Then Spaced = Spaced Else Spaced = 1
	    for i = 0 to BlobValue.size - 1
		    Result = Result & IIf(i = 0, PadRight(Hex(i), 0, 8), IIf(i mod 16, "", vbCRLF & PadRight(Hex(i), 0, 8)))  &  IIf(i=0, " ", IIF(i mod Spaced, "", " ")) & HHex(BlobValue(i))
	    next
	    BlobToHex = Trim(Result)
    Else
        BlobToHex = ""
    End If
End Function
Sub OutputBlob(ByVal BlobValue, ByVal Spaced)
	If DOpus.Typeof(BlobValue) = "object.Blob" Then Dopus.Output BlobToHex(BlobValue, Spaced)
End Sub
Function BlobToNumber(ByVal BlobValue)
        Select Case BlobValue.Size
            Case 1 BlobToNumber = CByte(BlobValue(0))
            Case 2 BlobToNumber = CLng(BlobValue(0) + BlobValue(1) * 2 ^ 8)
            Case 4 BlobToNumber = CLng(BlobValue(0) + BlobValue(1) * 2 ^ 8 + BlobValue(2) * 2 ^ 16 + BlobValue(3) * 2 ^ 24)
            Case Else BlobToNumber = 0
        End Select
    Else
        BlobToNumber = 0
    End If
End Function
'StringFormat("At {0} in {1}, the temperature was {2} degrees.", Array(123, "adc", 789))
Function FormatString(ByVal Format, ByVal Args)
    Dim RegExp, Result
    Result = Format
    Set RegExp = New RegExp
    With RegExp
        .Pattern = "\{(\d{1,2})\}"
        .IgnoreCase = False
        .Global = True
    End With
    Set matches = RegExp.Execute(Result)
    For Each match In matches
        dim index
        index = CInt(Mid(match.Value, 2, Len(match.Value) - 2))
        Result = Replace(Result, match.Value, Args(index))
    Next
    Set matches = nothing
    Set RegExp = nothing
    FormatString = Result
End Function
Function ReadTextFile(ByVal FilePath, ByVal FCharset)
    Dim FStream, Result
    Set FStream = CreateObject("ADODB.Stream")
    FStream.Type = adTypeText
    FStream.Mode = adModeRead
    If Len(FCharset) > 0 Then
        FStream.Charset = FCharset
        If Err.number <> 0 Then
            FStream.Charset = "_autodetect_all"
        End If
        On Error Goto 0
    End If
    FStream.Open
    FStream.LoadFromFile sFilePath
    Result = FStream.ReadText
    FStream.Close
    Set FStream = Nothing
    ReadTextFile = Result
End Function
Function GetType(ByVal Path)
    With CreateObject("Scripting.FileSystemObject")
        Path = .GetAbsolutePathName(Path)
        Select Case True
            Case .FileExists(Path)   : GetType = 1
            Case .FolderExists(Path) : If .GetFolder(Path).IsRootFolder Then GetType = 3 Else GetType = 2
            Case Else : GetType = 0
        End Select
    End With
End Function
Function Is_Exists(ByVal Path)
    Is_Exists = GetType(Path) <> 0
End Function
Function Is_File(ByVal Path)
    Is_File = GetType(Path) = 1
End Function
Function Is_Folder(ByVal Path)
    Is_Folder = GetType(Path) = 2 Or GetType(Path) = 3
End Function
Function Is_Root(ByVal Path)
    Is_Root = GetType(Path) = 3
End Function
'Author: Demon
'Date: 2011/11/10
'Website: http://demon.tw
Function is_valid_utf8(ByRef input) 'ByRef以提高效率
    Dim s, re
    Set re = New Regexp
    s = "[\xC0-\xDF]([^\x80-\xBF]|$)"
    s = s & "|[\xE0-\xEF].{0,1}([^\x80-\xBF]|$)"
    s = s & "|[\xF0-\xF7].{0,2}([^\x80-\xBF]|$)"
    s = s & "|[\xF8-\xFB].{0,3}([^\x80-\xBF]|$)"
    s = s & "|[\xFC-\xFD].{0,4}([^\x80-\xBF]|$)"
    s = s & "|[\xFE-\xFE].{0,5}([^\x80-\xBF]|$)"
    s = s & "|[\x00-\x7F][\x80-\xBF]"
    s = s & "|[\xC0-\xDF].[\x80-\xBF]"
    s = s & "|[\xE0-\xEF]..[\x80-\xBF]"
    s = s & "|[\xF0-\xF7]...[\x80-\xBF]"
    s = s & "|[\xF8-\xFB]....[\x80-\xBF]"
    s = s & "|[\xFC-\xFD].....[\x80-\xBF]"
    s = s & "|[\xFE-\xFE]......[\x80-\xBF]"
    s = s & "|^[\x80-\xBF]"
    re.Pattern = s
    is_valid_utf8 = (Not re.Test(input))
End Function
Function IsAscii(ByVal TextIn)
    Dim vRegExp
    Set vRegExp = New RegExp
    With vRegExp
        .IgnoreCase = False
        .Global = True
        .Pattern = "[\x09-\x0D\x20-\x7E]"
        IsAscii = (.Replace(TextIn, "") = "")
    End With
    Set vRegExp = Nothing
End Function
Function IsAnsi(ByVal TextIn)
    Dim vRegExp
    With vRegExp
        .IgnoreCase = False
        .Global = True
        .Pattern = "[\x00-\x08\x0E-\x1F\x7F]"
        IsAnsi = (TextIn = .Replace(TextIn, ""))
    End With
End Function
Function GetMachine(ByVal FileName)
    'https://msdn.microsoft.com/en-us/library/windows/desktop/ms680313(v=vs.85).aspx
    Dim File, Result, BValue
    'IMAGE_FILE_HEADER
    Dim Machine', NumberOfSections, TimeDateStamp, PointerToSymbolTable, NumberOfSymbols, SizeOfOptionalHeader, Characteristics
    Set File = DOpus.FSUtil.OpenFile(FileName)
    Set BValue = DOpus.Create.Blob()
	Result = IIf(File.Size = 0, GetResString("Empty"), IIf(File.Size < &H40, GetResString("Small"), ""))
    If File.Error = 0 And File.Size > &H3F Then
        File.Read BValue, 2
        If (BlobToNumber(BValue) = &H5A4D&) Then 'IMAGE_DOS_HEADER Magic number MZ
            File.Seek &H3C, "b"
            File.Read BValue, 4
            File.Seek BlobToNumber(BValue), "b"
            File.Read BValue, 4
            If BlobToNumber(BValue) = &H00004550& Then 'IMAGE_NT_HEADERS Signature PE00
                File.Read BValue, 2
                Machine = BlobToNumber(BValue)
                'File.Read BValue, 2
                'NumberOfSections = BlobToNumber(BValue)
                'File.Read BValue, 4
                'TimeDateStamp = BlobToNumber(BValue)
                ''Dopus.Output DateAdd("s", TimeDateStamp + TimeZone, #1970/01/01 00:00:00#) & " @ " & FileName
                'PointerToSymbolTable = BlobToNumber(BValue)
                'NumberOfSymbols = BlobToNumber(BValue)
                'SizeOfOptionalHeader = BlobToNumber(BValue)
                'Characteristics = BlobToNumber(BValu)
                Select Case Machine
                    Case &H014C& Result = "32-bit"
                    Case &H0200& Result = "64-bit(IA64)"
                    Case &H8664& Result = "64-bit"
                    Case Else    Result = "Unknown"
                End Select
            Else
                Result = GetResString("NotPE")
            End If
        End If
        BValue.Free
        File.Close
        Set BValue = Nothing : Set File = Nothing
    End If
    GetMachine = Result
End Function
Function DetectBOM(ByVal FileName)
    'https://en.wikipedia.org/wiki/Byte_order_mark
    Dim File, EnBlob, Result, i, StrBuf, ArrBuf
    Result = "--"
    'Set EnBlob = DOpus.Create.Blob()
    If File.Error = 0 Then
        If File.Size >= 2048 Then
            Set EnBlob = File.Read(2048)
        Else
        End If
        File.Close
        Set File = Nothing
    Else
        Result = "Error" ' GetResString("Error")
        File.Close
        DetectBOM = Result
        Set File = Nothing
        Exit Function
    End If
    Select Case CBool(True)
        Case (EnBlob.Size = 0)        Result = GetResString("Empty")
        Case (EnBlob.Size < 3)        Result = GetResString("Small")
        Case (EnBlob(0)  = &HF7 And EnBlob(1)  = &H64 And EnBlob(2)  = &H4C)        Result = "UTF-1"
        Case (EnBlob(0)  = &H2B And EnBlob(1)  = &H2F And EnBlob(2)  = &H76 And (EnBlob(3) = &H38 Or EnBlob(3) = &H39 Or EnBlob(3) = &H2B Or EnBlob(3) = &H2F))  Result = "UTF-7"
        Case (EnBlob(0)  = &HEF And EnBlob(1)  = &HBB And EnBlob(2)  = &HBF And EnBlob(3) <> &H00)                                                               Result = "UTF-8"
        Case (EnBlob(0) <> &H00 And EnBlob(1)  = &H00 And EnBlob(2) <> &H00 And EnBlob(3)  = &H00)                                                               Result = "UTF-16LE NO-BOM"
        Case (EnBlob(0)  = &H00 And EnBlob(1) <> &H00 And EnBlob(2)  = &H00 And EnBlob(3) <> &H00)                                                               Result = "UTF-16BE NO-BOM"
        Case (EnBlob(0)  = &HFF And EnBlob(1)  = &HFE And EnBlob(2) <> &H00)        Result = "UTF-16LE"
        Case (EnBlob(0)  = &HFE And EnBlob(1)  = &HFF)        Result = "UTF-16BE"
        Case (EnBlob(0)  = &HFF And EnBlob(1)  = &HFE And EnBlob(2)  = &H00 And EnBlob(3)  = &H00)                                                               Result = "UTF-32LE"
        Case (EnBlob(0)  = &H00 And EnBlob(1)  = &H00 And EnBlob(2)  = &HFE And EnBlob(3)  = &HFF)                                                               Result = "UTF-32BE"
        Case (EnBlob(0)  = &H84 And EnBlob(1)  = &H31 And EnBlob(2)  = &H95 And EnBlob(3)  = &H33)                                                               Result = "GB-18030"
        Case (EnBlob(0)  = &HFB And EnBlob(1)  = &HEE And EnBlob(2)  = &H28)        Result = "BOCU-1"
        Case (EnBlob(0)  = &H0E And EnBlob(1)  = &HFE And EnBlob(2)  = &HFF)        Result = "SCSU"
        Case (EnBlob(0)  = &H00 And EnBlob(1)  = &H00 And EnBlob(2)  = &HFF And EnBlob(3)  = &HFE)                                                               Result = "UCS-2143"
        Case (EnBlob(0)  = &HFE And EnBlob(1)  = &HFF And EnBlob(2)  = &H00 And EnBlob(3)  = &H00)                                                               Result = "UCS-3412"
        Case (EnBlob(0)  = &HDD And EnBlob(1)  = &H73 And EnBlob(2)  = &H66 And EnBlob(3)  = &H73)                                                               Result = "UTF-EBCDIC"
        Case (EnBlob(0)  = &H1B) ' https://en.wikipedia.org/wiki/ISO/IEC_2022
                Case (EnBlob(0) = &H1B And (EnBlob(1) = &H28 Or EnBlob(1) = &H24) And (EnBlob(2) = 40 Or EnBlob(2) = 42 Or EnBlob(2) = &H4A)) Result = "ISO-2022-JP"
                Case (EnBlob(0) = &H1B And EnBlob(1) = &H24 And EnBlob(2) = &H28) Result = "ISO-2022-JP-1"
                Case (EnBlob(0) = &H1B And (EnBlob(1) = &H24 Or EnBlob(1) = &H2E) And (EnBlob(2) = &H28 Or EnBlob(2) =&H41 Or EnBlob(2) =&H46)) Result = "ISO-2022-JP-2"
                Case (EnBlob(0) = &H1B And EnBlob(1) = &H28 And EnBlob(2) = &H49) Or (EnBlob(0) = &H1B And EnBlob(1) = &H24 And EnBlob(2) = &H28 And (EnBlob(3) = &H4F Or EnBlob(3) = &H50)) Result = "ISO-2022-JP-3"
                Case (EnBlob(0) = &H1B And EnBlob(1) = &H24 And EnBlob(2) =&H28 And EnBlob(2) =&H51) Result = "ISO-2022-JP-2004"
                Case (EnBlob(0) = &H1B And EnBlob(1) = &H24 And EnBlob(2) =&H29 And EnBlob(3) =&H43) Result = "ISO-2022-KR"
                Case (EnBlob(0) = &H1B And EnBlob(1) = &H24 And (EnBlob(2) = &H29 Or EnBlob(2) = &H2A) And (EnBlob(3) = &H41 Or EnBlob(3) = &H47 Or EnBlob(3) = &H48)) Result = "ISO-2022-CN"
                Case (EnBlob(0) = &H1B And EnBlob(1) = &H24 And (EnBlob(2) = &H29 Or EnBlob(2) = &H2B) And (EnBlob(3) = &H45 Or (EnBlob(3) >= &H49 And EnBlob(3) <= &H4D))) Result = "ISO-2022-CN-EXT"
            End Select
        Case Else
            ArrBuf = Join(EnBlob.ToVBArray)
            For i = 0 to EnBlob.Size - 1
                StrBuf = StrBuf + ChrW(EnBlob(i))
            Next
            If CBool(InStr(1, ArrBuf, " 13 0 10 0 ")) Or CBool(InStr(1, ArrBuf, " 32 0 ")) Then
            ElseIf CBool(InStr(1, ArrBuf, " 0 13 0 10 ")) Or CBool(InStr(1, ArrBuf, " 0 32 ")) Then
            Else
                Result = IIf(IsAscii(StrBuf), "ASCII", IIf(is_valid_utf8(StrBuf), "UTF-8 NO-BOM", "")) 'MaxByte <= 126 And IIf(MinByte = 9, True, IIf(MinByte = 10, True, IIf(MinByte = 13, True, IIf(MinByte >=32 And MinByte < 128, True, False))))
            End If
    End Select
    Set EnBlob = Nothing
    DetectBOM = Result
End Function
' Implement the Age columns
Function OnGetAge(AgeColData)
    Dim DDiff, ItemDate, GroupText
    If Is_Exists(AgeColData.Item.Realpath) Then
    'If DOpus.FSUtil.Exists(AgeColData.Item.Realpath) Then
        Select Case AgeColData.Col
            ' Case "AccessAge"
            '     ItemDate = AgeColData.Item.access : GroupText = GetResString("AccessAt")
            Case "CreateAge"
                ItemDate = AgeColData.Item.create : GroupText = GetResString("CreateAt")
            Case "ModifyAge"
                ItemDate = AgeColData.Item.modify : GroupText = GetResString("ModifyAt")
                'LogMsg AgeColData.Item & Chr(9) & " modify date time: " & ItemDate
        End Select
        if ItemDate >= #1970/01/01 00:00:00# And ItemDate <= Now() Then
            DDiff = DateDiff("n",ItemDate, Now())
            Select Case LCase(Script.Config.AgeUnit)
                Case "0" 'Auto
                        Case (DDiff  >= 0 And DDiff < 60) ' Minutes
                            AgeColData.value = DDiff & GetResString("minutes")
                            AgeColData.sort  = CDbl(DDiff / 10 ^ 9) + 0
                            AgeColData.Group = GroupText & GetResString("g-minutes")
                        Case (DDiff  >= 60 And DDiff < 1440) 'Hours
                            AgeColData.value = DDiff \ 60 & GetResString("hours")
                            AgeColData.sort  = CDbl(DDiff / 10 ^ 9) + 1
                            AgeColData.Group = GroupText & GetResString("g-hours")
                        Case (DDiff  >= 1440 And DDiff < 10080) 'Day
                            AgeColData.value = DDiff \ 1440 & GetResString("days")
                            AgeColData.sort  = CDbl(DDiff / 10 ^ 9) + 2
                            AgeColData.Group = GroupText & GetResString("g-days")
                        Case (DDiff  >= 10080 And DDiff < 43200) 'Week
                            AgeColData.value = DDiff \ 10080 & GetResString("weeks")
                            AgeColData.sort  = CDbl(DDiff / 10 ^ 9) + 3
                            AgeColData.Group = GroupText & GetResString("g-weeks")
                        Case (DDiff  >= 43200 And DDiff < 525960)
                            AgeColData.value = DDiff \ 43200 & GetResString("months")
                            AgeColData.sort  = CDbl(DDiff / 10 ^ 9) + 4
                            AgeColData.Group = GroupText & GetResString("g-months")
                        Case (DDiff  >= 525960) 'Year
                            AgeColData.value = DDiff \ 525960 & GetResString("years")
                            AgeColData.sort  = CDbl(DDiff / 10 ^ 9) + 5
                            AgeColData.Group = GroupText & GetResString("g-years")
                    End Select
                Case "1"  'Minutes
                Case "2"  'Hours
                Case "3"  'Day
                Case "4"  'Week
                Case "5"  'Month
                Case "6"  'Year
            End Select
        Else
            AgeColData.value = GetResString("Error")
            AgeColData.sort  = CDbl(DDiff / 10 ^ 9) + 6
            AgeColData.Group = GroupText & GetResString("g-Error")
        End If
    End If
End Function
Function OnGetCol(GetColData)
    If Is_Exists(GetColData.Item.Realpath) Then
        Select Case GetColData.Col
            Case "IsModified" ' Implement the IsModified column
                If Is_File(GetColData.Item.Realpath) Then 'Is_File(GetColData.Item)
                    If GetColData.Item.Create = GetColData.Item.Modify Then
                        GetColData.Sort = 2
                        GetColData.Group = "Never Modified"
                    Else
                        GetColData.value = Cstr(True)
                        GetColData.Sort = 1
                        GetColData.Group = "Modified"
                    End If
                Else
                    GetColData.Sort = 0
                    GetColData.Group = "Folder"
                End If
            Case "IsEmptyFile" ' Implement the EmptyFile column
                If Is_File(GetColData.Item.Realpath) Then GetColData.value = CStr(Not CBool(GetColData.Item.size)) 'And GetColData.Item.size = 0
            Case "Platform" ' Implement the Platform column
                If Is_File(GetColData.Item.Realpath) And (InStr(LCase(Script.Config.ExeFiles + "."), LCase(GetColData.Item.Ext + ".")) <> 0) And (Len(GetColData.Item.Ext) <> 0) Then
    	            GetColData.value = GetMachine(GetColData.Item)
                End If
            Case "TextEncode" ' Implement the Encoding column
                If Is_File(GetColData.Item.Realpath) And (InStr(LCase(Replace(Script.Config.TextFiles, vbCRLF, "") + "."), LCase(GetColData.item.Ext + ".")) <> 0) And (Len(GetColData.item.Ext) <> 0) Then
                    GetColData.value = DetectBOM(GetColData.item)
                End If
            Case "Signature" ' Implement the Signature column
                    Dim i, arrSig, arrString
                    If CBool(GetColData.Item.size) Then
                        arrSig = DOpus.FSUtil.OpenFile(GetColData.Item.Realpath).Read(5).ToVBArray
                        For i = 0 To UBound(arrSig)
                            GetColData.value = GetColData.value & Right("0" & Hex(arrSig(i)), 2) & " "
                            If (arrSig(i) >= 33) And (arrSig(i) <= 126) Then arrString = arrString & ChrW(arrSig(i)) Else arrString = arrString & ChrW(32)
                        Next
                        GetColData.value = "[" & Trim(GetColData.value) & "] [" & arrString & "]"
                    End If
                End If
        End Select
    End If
End Function
==SCRIPT RESOURCES
<resources>
    <resource type     = "strings">
        <strings lang  = "chs">
            <string id = "ScriptDesc"  text = "自定义列合集" />
            <string id = "IsEmptyFile" text = "空文件" />
            <string id = "IsModified"  text = "修改过" />
            <string id = "Platform"    text = "运行平台" />
            <string id = "TextEncode"  text = "文本编码" />
            <string id = "AccessAt"    text = "访问于" />
            <string id = "CreateAt"    text = "创建于" />
            <string id = "ModifyAt"    text = "修改于" />
            <string id = "Signature"   text = "文件签名" />
            <string id = "Empty"       text = "文件为空" />
            <string id = "Small"       text = "文件太小" />
            <string id = "NotPe"       text = "非 PE 格式文件" />
            <string id = "minutes"     text = " 分钟前" />
            <string id = "hours"       text = " 小时前" />
            <string id = "days"        text = " 天以前" />
            <string id = "weeks"       text = " 周以前" />
            <string id = "months"      text = " 月以前" />
            <string id = "years"       text = " 年以前" />
            <string id = "G-minutes"   text = " 一小时内" />
            <string id = "G-hours"     text = " 一天以内" />
            <string id = "G-days"      text = " 一周以内" />
            <string id = "G-weeks"     text = " 一月以内" />
            <string id = "G-months"    text = " 一年以内" />
            <string id = "G-years"     text = " 一年以上" />
            <string id = "Error"       text = " " />
            <string id = "G-Error"     text = " 日期错误" />
            <string id = "UnitAuto"    text = "自动" />
            <string id = "UnitMinutes" text = "分钟" />
            <string id = "UnitHours"   text = "小时" />
            <string id = "UnitDays"    text = "天" />
            <string id = "UnitWeeks"   text = "周" />
            <string id = "UnitMonths"  text = "月" />
            <string id = "UnitYear"    text = "年" />
            <string id = "AgeUnitDesc" text = "文件时间列单位" />
            <string id = "DebugDesc"   text = "脚本调试开关" />
            <string id = "PEFilesDesc" text = "PE 文件扩展名" />
            <string id = "TextFilesDesc" text = "文本文件扩展名" />
            <string id = "SiLength"    text = "读取文件签名长度" />
            <string id = "Other"       text = "其它" />
        </strings>
        <strings lang  = "english">
            <string id = "ScriptDesc"  text = "Customize the set of columns." />
            <string id = "IsEmptyFile" text = "Is Empty File" />
            <string id = "IsModified"  text = "Is Modified" />
            <string id = "Platform"    text = "Platform" />
            <string id = "TextEncode"  text = "Encoding" />
            <string id = "AccessAt"    text = "Access At" />
            <string id = "CreateAt"    text = "Create At" />
            <string id = "ModifyAt"    text = "Modify At" />
            <string id = "Signature"   text = "Signature" />
            <string id = "Empty"       text = "File is empty." />
            <string id = "Small"       text = "File too small." />
            <string id = "NotPe"       text = "Not PE file." />
            <string id = "minutes"     text = " minutes ago" />
            <string id = "hours"       text = " hours ago  " />
            <string id = "days"        text = " days ago   " />
            <string id = "weeks"       text = " weeks ago  " />
            <string id = "months"      text = " months ago " />
            <string id = "years"       text = " years ago  " />
            <string id = "Error"       text = " date error" />
            <string id = "G-minutes"   text = " within one hours"/>
            <string id = "G-hours"     text = " within one days"/>
            <string id = "G-Days"      text = " within one weeks"/>
            <string id = "G-Weeks"     Text = " within one months"/>
            <string id = "G-months"    text = " within one years"/>
            <string id = "G-Years"     Text = " More than one years"/>
            <string id = "G-Error"     text = " Date error" />
            <string id = "UnitAuto"    text = " Auto" />
            <string id = "UnitMinutes" text = " Minute" />
            <string id = "UnitHours"   text = " Hour" />
            <string id = "UnitDays"    text = " Day" />
            <string id = "UnitWeeks"   text = " Week" />
            <string id = "UnitMonths"  text = " Month" />
            <string id = "UnitYear"    text = " Year" />
            <string id = "AgeUnitDesc" text = "File age column unit." />
            <string id = "DebugDesc"   text = "Script debug switch." />
            <string id = "PEFilesDesc" text = "PE file extensions." />
            <string id = "TextFilesDesc" text = "Text file extensions." />
            <string id = "SiLength"    text = "Read the file signature length" />
            <string id = "Other"       text = "Other" />
        </strings>
    </resource>
</resources>
that script needs its own thread.
The Description column includes this information for .exe files.
I might update the column script for .exe files once I free myself some more time. Thanks for the Stackoverflow link.
Folks, pls advise how the above script,
that has resources embedded
can be successfully deployed,
thx
Have you tried the built-in Description column?
