I recently added a new tab to a saved lister...and now I've forgotten how to resave this lister to remember the configuration. Any suggestions would be great. Thanks. BTW, can somebody show me code that allows me to do just this? That's all.
Surely there aren't that many menus that it would take so long to find something you'd used in the past...
Settings -> Lister Layouts -> Save This Lister
Sorry...I am so used to Microsoft Word after resaving the same file the options on the File menu get greyed out. This is a signal to me that the file in question has already been saved and could only be done via the menu option...Save...and not Save as.
I was wondering if you should look into this...as when you save listers...sometimes you might forget you already have a lister with the name and be prompted to "You already have a lister with this name. Are you sure you want to save it?"
Never mind. I see you have already implemented this. Thanks anyway. Sorry for the hassle.
