If I have the format lock activated and I enable flat view with Set FLATVIEW=MixedNoFolders,toggleoff
, the folder format changes to the default Flat View format.
Is there a way to prevent that and keep the previous locked format?
I know I can use @if
to check if format lock is set, but I don't see a way of forcing the Flat View command to not change format then.
My guess is that the only way to do that is to save the current format to a temporary favorite and restore it after activating Flat View. Is that so?
