Frame & Fill\Fill tile Interior color
Hi;
I have set my Default DOPus Windows Start menu for…
a. No tree.
b. Tiles.
c. No Tile Frames.
Problem I am encountering with the Tiles Preferences…
Frame & Fill\Fill tile Interior… very bright colors are way off; bright red is a dull brownish red. Bright yellow is a very dark greenish yellow (SEE: attached Tile Background Color.jpeg... below). I don’t understand why these colors when applied to a Tile background do not match the color selected whereas most other DOpus colors are a perfect match on various buttons.
Dark colors seem to be OK.
Thanks;
Doc
Try turning off the applicable Blend options in Preferences / Display / Options.
Thanks;
I will look at that later as there are a lot Blend choices and need to try them one at a time to see the effects
Thanks again for your wonderful help;
Doc
