I am a new user to Directory Opus.
My Directory Opus ver. is 10.0.5.0.4497 x64
if Lock Folder switch is turn on
then Prog will always freezed after finding containing text.
I do that quite frequently without any problem.
Here's a short video; is anything I'm doing in the video different to what you're doing?
Do you only see the problem when searching within particular folders?
I got Error code 0xC0000005 on ver.10.0.5.0.4497 x64 when Opus Finding containing text freezed.
This problem seems to be solved after I intsalled ver. 10.0.5.3.4555 x64.
thx for your help.
