FTP and changing directory
Hi,
Changing directory by using mouse and selecting directory on tiltle bar doesn't work in version 8.1
for example:
You have ftp connection and "home directory" set to dir1/dir2/dir3
Selecting dir2 on tiltle bar and directory should change to dir1/dir2 but it is still dir1/dir2/dir3
In 8.0.1.2 it works
br
Darek
Confirmed
Thanks. Yes, this is an artifact of the change to support reuse of an FTP connect button or Site Entry while still connected. It thinks you are reconnecting so it will connect to the directory defined in the Site entry (if you have one).
We'll fix it for next version.
__
Greg.
Thanks for the answer.
So till the next version :slight_smile:
br
Darek
Yes. It's Richard's fault:)
