FTP Auto Resume - does not work!
Hello,
I'm trying to download big file (200Mb) from FTP. In the FTP connection, in the Network page, I set the use PASV, retry count 20 and automatically reconnect if connection lost.
in the miscellaneous page I checked the RESUME.
And the FTP still does not resume automatically !!
I tried the unattended operation: Resume (FTP only) but it does not change anything.
Please tell me if you have a solution that works.
Thanks,
Udi.
Does the server support resume?
Opus does not currently do automatic retry/resume after FTP download failures.
The auto-reconnect option just means Opus will try to reconnect to the FTP site if the connection is lost. (But it won't do anything after reconnecting; it just means it will be ready for you to tell it to do things.)
The resume option just allows you to force on/off resume support for the server, instead of the normal automatic detection. (Since some servers do not properly report their capabilities and resume doesn't work correctly with all servers.)
Turning them both on doesn't turn on auto-retry/resume, unfortunately.
