Hi!
I encountered a problem in Directory Opus when trying to access a local ftp server. I could connect successfully but folder names that consisted special Hungarian characters such as á, é, ő etc. weren't displayed correctly, these special letters were replaced by rectangles.
Total Commander handles them correctly, this is why I suppose it to be an error of Opus.
Total Commander's log is:
Connect to: (2009.03.08 20:36:12)
hostname=***********
username=***********
startdir=
**********.ch.bme.hu=*********
220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
220-You are user number 2 of 50 allowed.
220-Local time is now 20:36. Server port: 21.
220-This is a private system - No anonymous login
220-IPv6 connections are also welcome on this server.
220 You will be disconnected after 15 minutes of inactivity.
USER ***********
331 User ********** OK. Password required
PASS ***********
230-User ********* has group access to: 2000
230 OK. Current directory is /
SYST
215 UNIX Type: L8
FEAT
211-Extensions supported:
EPRT
IDLE
MDTM
SIZE
REST STREAM
MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
MLSD
TVFS
ESTP
PASV
EPSV
SPSV
ESTA
AUTH TLS
PBSZ
PROT
UTF8
211 End.
Connect ok!
PWD
257 "/" is your current location
Alkönyvtár
TYPE A
200 TYPE is now ASCII
PORT ***,**,*****
200 PORT command successful
LIST
150 Connecting to port 61101
Downloading
Waiting for server...
226-Options: -l
226 7 matches total
Opus establishes the connection with the following output:
*********:21 kapcsolat megnyitása
220-Local time is now 20:50. Server port: 21.
331 User ******** OK. Password required
230-User ******** has group access to: 2000
215 UNIX Type: L8
EPRT
IDLE
MDTM
SIZE
REST STREAM
MLSD
TVFS
ESTP
PASV
EPSV
SPSV
ESTA
AUTH TLS
PBSZ
PROT
UTF8
211 End.
200 OK, UTF-8 enabled
200 TYPE is now 8-bit binary
250 OK. Current directory is /
227 Entering Passive Mode (***,**,***,***)
150 Accepted data connection
226-Options: -a -F -l
226 9 matches total
643 bájt érkezett 0.27 másodperc alatt (22.472 Kbyte/sec)
What I get when trying to jump into a folder:
directory
Relative CD failed. Try absolute
550 Can't change directory to /Anal �s sztlen targyak: No such file or directory
Could anyone solve my problem, please?
