when i am using ftp mode the collumn for group is always empty. it's empty on my local file system as well but i guess that's normal on windows (don't know). not sure if that is an ftp or opus problem though.
Make sure you are using the correct Group column, since there are two of them.
The General > Group column is for when grouping the file display:
The Other > Group column (only available when on an FTP site) shows the Unix-style group which owns the files, as reported by the FTP server:
One some sites it'll show a group number instead of a group name. I guess on some sites it may be blank as well, since it depends on what (if anything) the server lists the file groups as.
thanks, that was the problem
