where in the Program Directory are the FTP info/settings stored? anyone know?
thanks
thanks
They're not, they're in the registry.
good enough - can you tell me where so i can export them and install them into my new (second OS) registry so as not to have to manually input them again?
googoogjoob (that means 'please', now) ?
HKEY_CURRENT_USER\Software\GPSoftware\Directory Opus\FTP
awesome. you're the Wal - Opus.
and i buried paul.
Would be easier to use the Settings / Import and Export utility to save and restore your settings (including FTP).
