In Opus 10 a ThreeState checkbox is used for password settings, but I can't find anything in the Help file about what the different states do. Could you explain?
If it's not in your copy of the Help file you might be using an old version of Opus.
Here's the page in the online version:
gpsoft.com.au/help/opus10/Documents/Site_Tab.htm
[quote="leo"]If it's not in your copy of the Help file you might be using an old version of Opus.
gpsoft.com.au/help/opus10/Documents/Site_Tab.htm[/quote]
Update Check says it's the current version.
I've attached a shot of what I could find in the Help file.
Thanks for pointing that out.
The info was on the "Sites Tab" page, but not the "Adding a new Site" page.
I've submitted a change to the manual so that both pages have the full information.
OK. Thanks!
