GetSizes - Deselect Side Effect
If I select several folders and then execute GetSizes, the folders are deselected. Easy enough to address by means of a button with @nodeselect but I would prefer if the selection was preserved by default.
Regards, AB
We'll be changing the default toolbar to include @nodeselect on the Edit > Calculate Folder Sizes menu item (which runs GetSizes). If you're using a custom toolbar (or don't want to reset once the new defaults arrive) then you'll still need to add it to your existing toolbar manually.
I normally trigger GetSizes with Ctrl-L. As a rule I try not to change the default settings for hotkeys but the obvious solution is to make an exception in this case.
Regards, AB
Ctrl+L is a toolbar hotkey (as opposed to a standalone hotkey) for Edit > Calculate Folder Sizes, so when the default toolbar changes you'll get the new command (assuming you adopt the new default Menu toolbar).
