Global Shortcut to System Properties
Greetings everyone,
One Windows Shortcut I like is Windows + Break/Pause (invokes System Properties), but it doesn't work on my laptop keyboard, even with all kinds of key substitutions mentioned here and there.
But I have set up a global shortcut to it. It is a convoluted procedure, and wonder if there would be an easier, more "global" way that would also work on a USB install of Opus.
I went to Control Panel, right-clicked "System", created a shortcut. Moved that shortcut to C:. In Opus, made a global shortcut pointing to that shortcut: System.lnk. It works, but would not work on USB.
Windows considers that System.lnk points to Control Panel\System. I tried pasting that in Opus without luck, is there an Opus syntax for it by any chance?
No worries if not, just would like to know the answer.
Warmest wishes to you all (25 degrees Celsius here in NZ)
The command "control system" will open the System control panel. You can bind that to a hotkey or button in Opus.
(It's a Windows command, not an Opus command, so it will work outside of Opus as well.)
YES!!!
Beautiful.
Thank you for that wonderful tip, Leo.
:slight_smile: :slight_smile: :slight_smile:
Wishing you a beautiful 25th of December
