Go command for Mobile device
I thought I had seen a way to set up a button to Go directly to a Mobile Device, in my case my Dell Axim. But I can't seem to locate it.
Thanks.
If dragging the device to a toolbar while in customize doesn't produce a button that works you can work around it by creating an Alias to the device, then a button which goes to the alias.
Creating an Alias
Go to Preferences, Favorites & Recent, Aliases, click Add and find the device in the tree. Give the alias whatever name you want (the same as the device if you like, but removing spaces will make life a bit easier).
Creating the Go button
Let's say you called the alias MyP900, then you just need to create a button which runs Go /MyP900
