I have added a button with a following command:
Go {filepath} CURRENT
I use it after find, to select some entry from the find results and go to it. It works nicely, but is broken if the result is within archive. For example, if the result is c:\temp\aa.zip\bb.txt, instead of going there, DOpus will jump to C:\Users...\AppData\Local\Temp\dtemp-d16fd148201750359-20.dop\bb.txt . I understand why it happens, but I believe it shouldn't happen in this scenario.
