GP SoftwareTwitter
Opus FAQsManualCommandsObjects
Help Doco updates
#1
https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Keywords_for_SetAttr_META.htm
Is missing command copyfrom, I.E. SetAttr META copyfrom: <type> , <filename>
https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Scripting/Item.htm
Is missing new property from 12.4 def_value.
#2
def_value is documented here, fwiw: https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Scripting/scriptingobjects.htm
It's supported by all the objects that have default values but isn't documented on any of the individual objects. I think it exists to help languages that cannot access the default value normally by providing a named property that gets the same thing.
