I keep looking things up in the help file, like rename codes, and finding that they're not yet documented.
Is there any guesstimate as to when a more complete (even if not fully polished) help file might come available?
Thanks,
Allen
Thanks,
Allen
It's almost done.
For now, use the online Opus 9 manual to fill in any gaps. (Also note that the beta versions of Opus 10 have more complete help-files than the older release versions, FWIW).
Thanks Leo. Unfortunately the rename keywords section is still not available, nor the metadata keywords. I'll check the previous version...
Hopefully "almost" means "soon"!
Allen
The metadata editor is new in Opus 10 so that won't be in the old manual, but you can find that information in the Opus 10 What's New.pdf in the Start Menu, in the section Programmatic Setting of Metadata towards the end. (Page 35 / 52).
Aha! Thanks for that.
Allen
