Help needed with renaming
Hi there,
i want to rename a bunch of files (99 to be exact) with the following pattern:
01 - song1.mp3
02 - song2.mp3
99 - song99.mp3
to
song1.mp3
song2.mp3
song99.mp3
Is this better done with search and replace or with regular expressions?
I simply don't find out, what to do...
Hi Ralph,
Rename Pattern=(.*)song(.*).mp3 To song\2.mp3 regexp
This results in
song1.mp3
song2.mp3
song99.mp3
Let us know if this works for you.
Or if you would prefer a bit different result ,
I know that several of us would enjoy the challenge.
:opusicon: porcupine
That would work providing the songs are actually named "song" porc however I have a hunch Ralph's taste in music is a little more varied towards music with other titles.
This works for me as long as none of the actual song titles have a - in the name (other than the one after the numbers)
Hi John !
Quite Right !
I have a feeling that Ralph may want a result that results in 01, 02 , ....
Well, we'll see.
Well Ralph ??
Thanks for the followup John.
Thanks John and Porcupine! John was pretty right about my music taste. What i wanted to do, was to "crop" or delete the first 5 (XX_-_) chars of the songs titles.
This brings me to John's mentioned problem when a - is in the song title: Wouldn't it be easier to just crop the first X chars of the original string?
Since all your leading numbers have 2 digits, yes, you could do that too with a find RegEx of:
And a replace RegEx of:
\1
The one thing you would want to ensure however, is that only the desired files are selected before you run the renaming operation for the above will strip the first 5 characters of any file with 5 characters or longer.
[quote="ralph76"]Hi there,
01 - song1.mp3
02 - song2.mp3
99 - song99.mp3
to
song1.mp3
song2.mp3
song99.mp3
I simply don't find out, what to do...[/quote]
No..
It's very easy.
Sellect all the song.
Sellect Files>Commands>Rename (i've made hot keys (left alt+shift+R) to do this).
In your example you would replace song1.mp3 with and astrisk (*) and in the new name box just an astrisk.
Hit Enter.
If you mess up, Edit>Undo will put it back.
Landis.
Hi Lunar,
This was a bit of a for me.
I misunderstood the post and thought ralph 76 literally meant that his filenames included 'song' !
It was a logical end though.
I had no knowledge from Ralph's post to the contrary :wink: .
In hindsight, this is a better answer.
old name:
^[0-9]+( - )(.*)
new name:
\2
Or even
old name:
(^[0-9]+)( - )(.*)[0-9]+(\..*)
new name:
\3\1\4
Regards,
Zippo
