Help Notes Apparent URL incorrect
Trivial link correction in help URL
In the Help notes the Command Modifier Reference has an entry shown below for the @nodeselect modifier.
The URL points to this location: File Display Options
I think it should point to here:
[https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Prefs/File_Operations_Options.htm](Prefs > File Operations > Options)
In relation to the above the Help notes seem a bit out of of sync with the Settings > Preferences dialog in the same area.
See below.
I only make these observations because Opus is such a fantastic product and that standard extends to exceptional documentation and help notes. I am assuming that you would want to know!
Respectfully and thankfully
Opus Fan Shaun
