HELP please, program no open
Hi all, when i want open opus, nothing apeared on screen, i don't no why ! please ..... help me ( i have already reconnect aplication )
have you tried rebooting your computer?
Is the Opus icon down by the clock in the system tray?
If you hit CTRL+ALT+DEL to bring up the task manager do you see the Opus icon there in applications? While you're in the task manager switch to the processes tab and see if DOpus.exe or dopusrt.exe are listed under the image name column.
Yes i have already reboot but same problem, icone are not in the bar of notification ! I will clean the base of the register and desisntaller the program...
