I've successfully used the SHA-1 Checksum function in the past (also MD5),
but today trying to check a BraveBrowserStandaloneSetup.exe file from
I don't get a match to the BraveBrowserStandaloneSetup.exe.sha256 file
and it's likely I'm not following a correct procedure.
When I open the BraveBrowserStandaloneSetup.exe.sha256 file in Notepad++ it shows:
7a515dd9a6c98c6ad9ae7854752f04825b5ef709b8f6b4c7c6904458fa1d1167 BraveBrowserStandaloneSetup_114_1_52_126.exe
But when I highlight the BraveBrowserStandaloneSetup.exe file then click on dOpus SHA-1
and copy to clipboard, it shows:
BraveBrowserStandaloneSetup.exe.sha256 : a46005d7c3df9b6fa74a5b162d4fe882b0d81014
I'd appreciate help to learn about and understand this, Thanks ~
