Help with button... Copy Here with Increment
I'm trying to make a button that will duplicate and increment if the file already exists.
My.txt => My-01.txt
My.txt => My-02.txt (if My-01.txt already exists in the target folder)
My.txt => My-03.txt (if My-01.txt and My-02.txt already exist in the target folder)
etc.
(Second attempt at adding a reply to this)
Here's the button code I use to do something pretty similar.
Copy DUPLICATE AS * WHENEXISTS=rename HERE
It doesn't append -01 to the file, rather it appends (1) to the file. Off the top of my head I don't remember a way to do exactly what you want unless you wrote a script to do it.
Thanks!
