@fred
Did you try that powershell solution I posted a while back?
@biggus
And if yes, what was wrong with it, so you made your own?
If I'm not wrong, your batch runs ffmpeg.exe multiple times like "file-x" + "file-x+1" until all files got appened, correct?
That powershell version does it all in one go, running ffmpeg.exe a single time only.
No, I didn't try it truth be told. I hate installing things, and I wanted to try and make it work myself.
I am so lame that I did not (until now) realise that I already HAVE powershell, and I don't need to download and install anything. doh! Talk about stuck in the past
Armed with this newfound knowledge, I will go back and try your method. My method works, I learned stuff, so it served its purpose.
I am curious about this powershell thing, and am keen to try your solution.
I don't think ffmpeg is called multiple times, but I don't know for certain? All the batch does is to use opus to build a text file, which is passed to ffmeg once, which then parses the files listed via the echo command.
Ultimately, I just want something that is simple, works, and is reasonably bulletproof. Mine works, but is about as bulletproof as cotton
I will report back, but tomorrow, doing stuff late at night isn't my best trick.
I don't even really want ffmpeg in particular, I just want a way to losslessly join mp3 files properly via a command line. I only know of ONE program that can do this properly aside from ffmepg (mp3merge) but that program does not support the command line as far as I can tell, so ffmpeg became the tool of choice, despite its amazinging finicky command line requirements.
If you know of a better way to join mp3s losslessly via a command line (thus via Opus), feel free to point me at it
Yes, yours works fine and slightly differently from mine, from what I see in the command window. The two methods produce what is almost the same file; yours is 300-400 K larger (this is in a 30 MB joined file) but retains some of the metadata, mine gets none of the metadata. The metadata is a non-event though. Yours seems to be slightly faster and is definitely more elegant. The downside is that I have not the slightest clue how it works, which I wouldn't care about normally, but I need to modify it slightly so that rather than pull the output filename from the base selected file name, I need a dialog so I can specify the output file name. I can see how in the psi file the '_joined gets added', but I don't have the faintest clue how to modify that so I can input the desired output file name.
Basically, I am joining the tracks in an audio book rip, and there would typically be say 10 CDs, each with say 20-30 tracks. This works nicely in grouped flat mode and ... doh, yours doesn't work in this mode, for the same reason I assume that my original batch doesn't work! I can read Opus' command lines ok, but I don't know to to read and adjust the psi file to account for flat mode. Bummer
Also, is there a way to close that cmd window after exection similar to using 'pause'? In other words a way to force the window to remain open so I can see stuff, but be able to close it with any keypress?
I guess I could use runmode hide, or just comment out your leavedoswindow open, but that being able to both see any potential issues and then hit any key afterward is handy. This may not be possible?
I will check back tomorrow, and in any case, ta, this has been a learning experince.
One last thing... this all comes about because no-one could figure out a way using Opus alone, to build the command line with the pipe as the seperator betwixt the files, eg
"concat:D:\files to merge\1.mp3|D:\files to merge\2.mp3|D:\files to merge\3.mp3 etc"
I guess this is why you resorted to Powershell in the first place?
Yes, for DOpus v10 that was the reason (no internal scripting).
I guess adding "Pause" to the end of the button and removing @leavedoswindowopen should do what you want.
I must admit I don't understand why and how your batch works! I see you add files to list.txt-file. After that the buttons runs ffmpeg.exe and deletes the list.txt-file.
What makes me wonder is, how the "echo >>" is done for all files, but ffmpeg.exe and the delete is done only once (is that really the case?). Mhh.. o)
Besides I wonder why people merge mp3s, want I do most often is splitting them, strange! o))
Here is a version which sports your dialog and flatview support. Powershell code "within", so paste the little v1.1 part to join.ps1 if you're curious to try. o)
Lol, no, this won't work, because the window does not close as it does in the case of a normal command window. I have to say I don't really know why, but suffice it to say that it doesn't, so adding pause does nothing apart from adding a keypress for no gain.
[quote]I must admit I don't understand why and how your batch works! I see you add files to list.txt-file. After that the buttons runs ffmpeg.exe and deletes the list.txt-file.
What makes me wonder is, how the "echo >>" is done for all files, but ffmpeg.exe and the delete is done only once (is that really the case?). Mhh.. o)[/quote]
I guess that makes us even, I don't understand how yours works either
You can test this by adding a second echo command after the first and you will see that is only done once. eg
AHA! SO you are one of these splitter types eh? I would ask why you would split them? There is no need to and splitting in the majority of cases screws things up big time. Every time now that I hear the disaster that ususally (though not always) accompanies split files, I will wonder if you are the culprit
I never used to join them, but I tend to now. The reason is simple. Audio book CDs typically have a lot more tracks on them than a normal music CD has. Ripping a whole CD worth of tracks securely is often probematical, so it is a lot simpler to rip tracks (as opposed to rippping 'as one') then join the tracks after the rip. If you weren't ripping securely this wouldn't be an issue, but if you aren't ripping securely then you may as well not bother.
I did. It confirmed me that I hate powershell on my current system. It's a pain to make it work. And if I have to choose a tool to learn, I go for AutoIt. I assume you can get some more polished results with it and in a easier way.
I've just built a new PC with win 8.1 x64 pro and this week I will migrate from XP SP3 x86 and install DOPUS 11.5 that I purchased. I can't wait to use its built in script feature for button.
Please post a dopus script handling the first post. It will be a good example to start with for me.
Next week-end I will tell you guys how I acclimated to my new system with those script features.
I must admit that I rarely need to do that but when I needed it, every time I told myself it would be cool to have the one click action for that. I already have some buttons that tells ffmpeg to do stuff and it's an amazing tool to handle all kind of media file no matter what your needs about them. I should have get multiple GUI apps to do the same. Dopus + command line app = power.
You don't need scripting or Opus 11 to do what you first asked. This works fine...
@nofilenamequoting
echo >>c:\list.txt file '{fs}'
"C:\Program Files\Serviio\lib\ffmpeg.exe" -f concat -i c:\list.txt -c copy "{d!}{Rs|Output file name? (mp3 will be appended)}.mp3"
del c:\list.txt
pause
Obviously change the path to ffmpeg to suit.
The solution that tbone initially posted (using powershell) does the same thing, though in a slightly different and definitely more elegant way. His 2nd solution, to work around the flat mode problem and my need to control the output file name, doesn't work, but I am sure it will shortly. Just a typo or a missed character rather than it not working per se.
Sorry but a internal script (as the dopus built in functionq that you may already use into some of your buttons) is more elegant than call a dos cmd, IMHO. I try to avoid them as much as I can, the result is always better for me, more elegant.
Thanks tbone, but I am snookered. I can't see how to, umm, not even sure how to put this, I can see how to implement this. I am a noob in this area so go easy on me. I dnd the script (after dropping the txt extension) to the prefs/scripts window, nothing appears to happen, but the script is copied to /script addins, but then... how do I use/call it? It doesn't appear to do what the docs or your instructions tell me, though this is probably me not understanding how to do it.
Hey Jon, thanks, that's how I interpreted what would happen, but I must be missing something, I can't see the function anwhere.
I downloaded the script, chopped the .txt off the end, dragged it to the prefs/toolbars/scripts window. Nothing appears to happen and nothing changes within that window, but the .js file is copied to script/add ins, so that part seems to work. But then...? Where is 'at' to add from? The standard Opus JOIN is there, but no JoinMP3.
