Hey guys,
Needed some help with a simple reg expression rename, let me know if you can help out
What I have is hundreds of files named this way:
DCT 30-01 sample text.doc
DCT 30-04 sample text.doc
DCT 30-21 sample text.doc
DCT 30-34 sample text.doc
What I want to do is replace the 30 with the two digital number after the dash - ("01,04,21,34") and then replace the two digit number with "07". So it should be like
DCT 01-07 sample text.doc
DCT 04-07 sample text.doc
DCT 21-07 sample text.doc
DCT 34-07 sample text.doc
Let me know if this is even do-able
thanks ![]()
okay, now if the "sample text" is always different text, how do I keep that in the new name
