Help with Rename using Regular Expressions
I need to rename files:
x.jpg y
to
in other words, I need to remove "y" which can consist of any number of characters.
I guess that the only way is to use regular expressions? What would the expressions need to be?
TIA
So what you are saying is, you have filenames of the form:
and you want to strip off the ?
If so, just use the "standard rename" mode, with:
old name: .jpg
new name: *.jpg
[quote="jon"]So what you are saying is, you have filenames of the form:
old name: .jpg
new name: *.jpg[/quote]
Correct. Oh that was trivial!
Thanks!
I had tried to use
old name: .jpg
as suggested above, but nothing was selected in the preview so I thought that it was not working. However, when I also added
new name: *.jpg,
the files were selected.
Why don't the files get selected in the preview until the "new name" is added? With Find/Replace they are selected after the Find field is populated.
Because you can replace a sub-string with "nothing", whereas in normal rename mode a new name pattern is also needed (otherwise the new filenames would end up blank).
