Help with Wildcard Label Assignment
Hi,
I'm trying to make a wildcard label assignment. However, I don't want it to include the inside folders and stop on match. I have two folders:
Instagram
Instagram Stories
*Instagram This wildcard works for the Instagram folder but I can't figure out how to get this wildcard assignment to work on both the Instagram & Instagram stories folder. *X + any other word after. I tried using the wildcard documentation but after 10 mins of failure I thought I'd just ask for a little help. My thought was maybe using the ? widlcard? Like, *Instagram ? but of course that didn't work.
Thoughts?
This might work
That worked great, thank you! I see my mistake as I did think of using the asterisk at the end but I never unchecked the "Match Full Path" with it. I see my mistake in thinking and thank you for answering my question.
Cheers!
