Hide Filter won't stay
I'm trying to hide a particular folder by going into Folder Options for the parent folder, then to Filters, then adding the folder's name to the Folders portion of the Hide Filter section.
When I click OK the folder gets hidden, but after restarting DOpus the folder is visible and the filter is reset.
How can I get it to stick?
Use the Save button at the top of the Folder Options window.
