Hiding Drive Letters in SendTo
Is there a way to hide drive letters in the SendTo menu that will never be needed to "Send To"?
Regards,
Chuck Billow
smallvoid.com/article/winnt-send ... rives.html
Leo, that sesms to work fine -- outside of DOpus. All the drive letters still show there.
Regards,
Chuck Billow
You might need to restart Opus. If it still makes no difference then there might not be a way (though you could replace the Send To menu with one of your own with just what you want).
OK...thanks.
Chuck
If you grab Opus 9.1.2.2 then it should work now.
