Hi!
I've recently bought a retina macbook and am running windows and Dopus on it. Dopus copes really well actually and never looked better - aside from the navigation buttons at the top of each lister looking tiny, things are good. The only issue I am struggling with is the size of fonts. On the native (2880x1800) screen fonts appear small as you would expect, and I adjust them upwards in each of the (8-10) font setting areas. When plugged into my external monitor at work, the text is then very large and I adjust them back one by one again!
I certainly wouldn't expect baked-in support for my use-case given that Windows is yet to crack the High DPI nut itself, but is there a quick way to:
a) Quick change between settings files? (link a couple of buttons to two settings files and apply it immediately)
b) Globally change the fonts rather than going through every subsection each time?
Thanks for your time
Mark
