I just discovered the "pin to top" option for Labels and I'm excited. However I've noticed that if my files are grouped, pinned files sort to the top of the group.
Can an option be made enable a high priority group for pinned items that sorts to the top of the lister if grouping is enabled?
You mean a separate "Pinned" group? We could probably add that.
Note that as Leo said in the other thread, pinned files don't work spectacularly well at the moment (they only jump to the top when they're displayed, which works in small folders but not so well in big ones). We're aiming to improve this in the future but it's a complicated change so not sure when it'll happen.
