Horizontal and Verical Lister
Currently I have two buttons.
F10 = Horizontal Dual Lister which is set to this function set DUAL=Horiz,Toggle
F11 = Veritical Dual Lister which is set to set DUAL=Vert,Toggle
If I am in a Horizontal Lister and I'd like to switch to a Vertical Lister, I have to press F10 to toggle to single Lister and then, press F11 to switch to Vertical Lister.
Ideally, I would like one button to switch between Horizontal and Vertical Lister and vice versa, without having to switch to a single Lister as intermediary before switching, i.e.
F10 = switch between Horizontal and Vertical
F11 = switch between single to dual Lister
I tried to do F10 as set DUAL=Horiz,Vert and that does not seem to work.
Is this possible?
Try
Set DUAL=togglelayout
https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Set.htm
Beautiful! That works! Thank you so much!
I have set F10 as Set DUAL=togglelayout and
F11 as Set DUAL=toggle,remember
The remember is so that it will remember the last lister tabs when it is reopened.
I use the Dual Display icon, custom Commands. Once I load it I going to custom commands and change the existing code to the following:
Set DUAL=Toggle,Vert,ToggleLayout
Set DUAL=Toggle,Horiz,ToggleLayout
When I did a test It did not work for me. But after I restart my computer it was working fine.
Bob
