Horizontal Justification for toolbar buttons
Feature request: Horizontal spacing for toolbar buttons (if a user moves between different horizontal resolutions the remaining space on the right shifts. In other words this option will ignore the horizontal spacing and use the entire toolbar with an equal spread between icons irregardless of the resolution of the screen. It may be an option for vertical toolbars as well.
You can do this already, although it takes some manual effort to set up.
Put a Full Width Spacer between each item you want to be spaced out. All the spacers will then share the available space and spread things out evenly.
That solution fails to work, it shoves the rightmost icons off the screen on the lower resolution and it's a nightmare to manage.
