Hotkey for copying
Is it possible to define a hotkey e.g. ctrl+F9 that copies the left folder (dual view) to the right?
TX
KEJ
Yup, the command is:
Go CURRENT OPENINDUAL
You can create a standalone hotkey for that, or you can create a toolbar button which runs the command and also has a hotkey. It's up to you. If you're not sure how to do either have a look at the Toolbar editing tutorial to learn the basics, then look at the Keys tab of the Customize dialog (via the Settings menu) if you want a standalone hotkey.
Thanks for the reply. I tried to create a key in customize/keys and used the command "copy". And it just works...
I love it when a program does what I want :slight_smile:
Tx
KEJ
Oh, you wanted to copy the selected files from left to right? I thought you wanted to show the same folder in the right. :slight_smile:
Glad it's doing what you want, anyway.
By the way, you could have also edited the Copy button on your toolbar to give it a hotkey. Same result but now the "Copy" command is only in one place which is a bit tidier, although it doesn't make a huge difference.
