Hotkey in popup menu do not work proper
I use hotkey for some programs in popup menu on floating toolbar . This shortcut key opens that submenu (popup menu) from floating toolbar and it works very well. If I have other program open maximized, I use Ctrl+Shift+D and popup menu from placed on left floating toolbar appears (without main floating toolbar visible itself if is covered by other program). In Opus installed on my laptop this hotkey function for popup menu is not working - or only working rarely (it works just once after I close customize window for example). Any suggestion why? I've checked possible key conflict and found nothing.
Anything different about the setups on the two machines? Is Opus running elevated (whole program run as admin, not admin mode after launching the program) on the laptop? (That may cause problems with hotkeys when non-elevated apps have focus.)
Nothing so different except laptop is old and has 32 bit Win7 while desktop - 64 bit Win7.
