Hovering does not open folder during drag-and-dro[
When I hover over the a folder in the Folder Tree during a drag/drop, the folder opens after a second or so. The same does not happen in the lister. I cannot find a setting for this (I have looked in all the usual places).
Am I overlooking something?
Regards,
Hans L
You're not overlooking anything; it's just something that doesn't happen. (Do any programs work like that?)
If you want to move things into a sub-folder using only a single file display, without any tree or anything else, then using Ctrl-X and Ctrl-V are probably the best way.
Okay, Nudel, I'll have to start getting used to Copy and Paste. I have started using that method – it is just to remember that the expansion does not work in listers :slight_smile:
Thanks,
Hans L
